XMC™ MCU: FreeRTOS_ Blinky and Watchdog_Timer code examples in KIT_XMC72_EVK running issue in ModusToolbox™ 3.0 – KBA236543
Infineon_Team
Version: **
When performing various program or debug operations using the Eclipse IDE on Windows, the plugin has a defect, that prevent the debug port from powering down.
This issue can be seen in ModusToolbox™ tools package release notes.
A quick workaround is to power the kit cycle once, the programming is complete.
Note:  This KBA applies to the following series of XMC7000 MCUs:
  • XMC7100 series
  • XMC7200 series
