Writing Time to Flash Memory for 32-bit Access in Traveo CY9D560 Series MCUs – KBA225706
Community-Team
50 questions asked 10 questions asked 5 questions asked
Author: shusakus_56          Version: **
Translation - Japanese: Traveo CY9D560シリーズMCUの32ビットアクセス用のフラッシュメモリへの書き込み時間 – KBA225706 - Community Translated (JA)
Question:
What is the time to write to a flash memory with 32-bit access in Traveo CY9D560 series MCUs?
Answer:
The writing time with 32-bit access is "16-bit write time × 2 = 768 μs (MAX)". When ECC is enabled, add 288 μs (MAX) to 768 μs (MAX).
Note:
The prefix MB of the product has been changed to CY. For instance, MB9D56X has been changed to CY9D56X.
Contributors
