Jul 04, 2022
03:11 AM
- Mark as Read
- Email to a Friend
- Printer Friendly Page
Workaround for error in service launch sequence - KBA235677
Version: **
If you get an error in service launch sequence while debugging in DAVE™ IDE as shown in Figure 1, then follow the workaround to resolve the error.
Figure 1 Error in services launch sequence
- Verify that you have installed Segger JLink.
- If you have not changed the installation path during DAVE™ setup, then the Segger JLink.exe files are in the default location C:\Program Files\SEGGER\JLink_V510l
- Verify that your debugger is configured as shown in Figure 2.
Figure 2 Debugger configuration window
- Restart Dave™ and debug the code.
Labels
Rate this article:
