Width and Depth Expansion of the CY7C1021 (64K x 16) SRAM
11:46 AM
- Mark as Read
- Printer Friendly Page
Mar 24, 2011
11:46 AM
Question: What is the recommended method to increase width and depth of SRAM
Answer:
Depth Expansion: Connect to each other 16 bit address lines and 16 bit data lines respectively of both the SRAMs and use the chip select as 17th address line to select one memory chip. Now we have total depth of Memory is 128K x 16 bits.
Width Expansion: Combine 16-bit data bus of each chip and use it as 32-bit data bus, connect to each other 16 bit address lines respectively. Now total width of memory is 64K x 32 bits.
Labels
- async fast srams
Rate this article:
Contributors
This widget could not be displayed.Anonymous
