Why should I use CoolSiC™ MOSFET devices?
Infineon_Team
1) Excelling performance, reliability and ease-of-use.
2) CoolSiC™ MOSFETs can reduce switching losses up to 80% and conduction losses up to 50% (compared to Si based IGBTs, depending on the load conditions)
3) CoolSiC™ MOSFETs show better FOM-figure of merits-compared to CoolMOS™ superjunction MOSFETs. This enables new topologies and designs that can cut power losses by 30% and double power density
4) In addition to this, CoolSiC™ MOSFETs enable engineers to reduce system costs by increasing power density (reducing magnetics, heat sinks, cases…)
