Why is my ModusToolbox Project for CY8CPROTO-062-4343W not building?
Infineon_Team
If you are using an Infineon example application, make sure that your project workspace contains a directory for your project and an mtb_shared directory. If the mtb_shared directory is missing, you need to create a new ModusToolbox application, it will be automatically generated.
If you have created your own project, the error is caused by either the name of your makefile or the location of your makefile. First check that your makefile is called 'makefile'. If not, you can either rename it or use 'make -f YOUR_MAKEFILE_NAME.mk'. Second, make sure the makefile is in the root of your project, i.e. 'YOUR_PROJECT/Makefile'. If not, you need to move it there.
Contributors
