Why does my PC not recognize TLE493D-P2B6 kit when using MS2go GUI?
Infineon_Team
PC cannot establish a data connection with the TLE493D-P2B6MS2GO kit, you have to make sure of that by looking in the device manager. Usually, this is the case if a USB cable is used that only supports charging but no data connection. Use a different USB cable, from which you know that it´s capable of data transfer.
