Why do your address pins not match Samsungs or other vendors?
11:13 AM
- Mark as Read
- Printer Friendly Page
Mar 02, 2011
11:13 AM
Translation - Japanese: SRAMのアドレスピンがSamsungや他ベンダーと異なる理由。
Question: Parts by other vendors are obsolete. In the Cypress equivalent part the address and data lines are different. Can i use Cypress part without changes in firmware?
Answer:
The address can be laid out in any order. The address pinout in the case of any sram does not matter since internally you might be addressing different locations but externally you read and write from the same location. Please refer to the following appnote for further clarification. AN1083
Labels
- async fast srams
- async micropower (mobla) srams
- dual-port srams
- fifos
- mobl dual-ports
- nonvolatile ram
- quadporta dse srams
- synchronous srams
Rate this article:
Contributors
This widget could not be displayed.Anonymous
