Why are some channels prioritized in TLE987x?
May 24, 2022
02:16 AM
- Mark as Read
- Printer Friendly Page
May 24, 2022
02:16 AM
Community Translation: TLE987x で一部のチャネルが優先されるのはなぜですか? (KA-01398)
In TLE987x Channels 0 - 5 can be fully programmed. Several Sequence registers, especially for channels 6-9, are protected to ensure a fast update of measurement results used for internal diagnosis. Hence the channels 6 and 7 are prioritized and are measured more often. The high prioritization is given by an enabled measurement for each sequence. They cannot be switched off. All other channels are not enabled in far fewer sequences. Thus, for enabled channels (not 6,7) the update rate (periodicity) is lower, but defined by the channels 6 and 7. Hence, overall periodicity is mainly determined by these two channels.
Labels
Rate this article:
