Why P0.1dB compression point cannot be measured for BGSX22G6U10?
Infineon_Team
The calculated P0.1dB point for the switch is higher than the device's maximum power handling capability. Therefore P0.1dB compression point cannot be measured for BGSX22G6U10. The maximum power before damage is for this device at 39dBm. So the P0.1dB is higher than this power.
Contributors
