What is the benefit of XDPL8219 Secondary Side Regulation (SSR)?
IFX_Publisher1
250 sign-ins First comment on KBA 250 replies posted
With SSR, the flyback converter output voltage can be adapted according to the LED voltage connected on the secondary stage buck converter output, for system efficiency improvement. As compared to the primary side regulation (PSR), SSR can also achieve a more accurate steady-state output voltage at no-load or light-load conditions.
