What are the suitable MOSFETs for battery powered BLDC motor drives?
Infineon_Team
For battery-powered applications in the 12 V to 72 V battery range Infineon offers OptiMOS™ and StrongIRFET™ N-Channel power MOSFETs, which are available in a wide range of leaded and SMD packages with many voltage and RDS(on) options including best-in-class devices ideally suited for applications such as power and gardening tools as well as robotics.
