What are the direct replacements for C166 and XE166 Microcontrollers?
vouria
10 questions asked 25 sign-ins 5 replies posted
There are no microcontrollers that can be used as a direct replacement to C166, or XE166.
Infineon does not produce 8-bit or 16-bit microcontrollers, and only produces 32 bit microcontrollers.
In order to choose a microcontroller among Infineon's active microcontrollers, "Infineon Solution Finder" or Infineon's "Finder & Selection Tool" can be used.
https://solutionfinder.infineon.com/application/en
https://www.infineon.com/cms/en/design-support/finder-selection-tools/
Contributors
