WPA Supplicant with bcmdhd
1. First follow this to prepare your iMX.
Quick Start with iMX6 Ultralite EVK and Mass Market Modules
2. Below are logs which shows using WPA supplicant with bcmdhd.
3. Below restart_wpa_supplicant is a script. The commands in it are
     killall wpa_supplicant
     wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf -D nl80211
root@imx6ulevk:~# ./bcm_imx/scripts/insmod_dhd.sh
FW=/lib/firmware/bcm/fw_bcmdhd.bin
NVRAM=/lib/firmware/bcm/bcmdhd.cal
dhd_module_init in
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
mmc0: new high speed SDIO card at address 0001
F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x3
DHD: dongle ram size is set to 524288(orig 524288) at 0x0
wifi_platform_get_mac_addr
CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211)
wl_create_event_handler(): thread:wl_event_handler:4da started
CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0x88f4141c
dhd_attach(): thread:dhd_watchdog_thread:4db started
dhd_attach(): thread:dhd_dpc:4dc started
dhd_deferred_work_init: work queue initialized
dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
Firmware up: op_mode=0x0005, MAC=98:f1:70:6e:8b:08
Firmware version = wl0: Dec 29 2015 15:56:15 version 7.45.41.24 (r608913) FWID 01-4e412465
dhd_wlfc_init(): successfully enabled bdcv2 tlv signaling, 79
dhd_wlfc_init: query wlfc_mode succeed, fw_caps=0x1c
dhd_wlfc_init(): wlfc_mode=0x1c, ret=0
Dongle Host Driver, version 1.141.88 (r)
Compiled from
Register interface [wlan0]  MAC: 98:f1:70:6e:8b:08
root@imx6ulevk:~# CFG80211-ERROR) wl_update_wiphybands : error reading vhtmode (-23)
CFG80211-ERROR) wl_cfg80211_connect : Connecting withff:ff:ff:ff:ff:ff channel (0) ssid "NexusV", len (6)
wl_bss_connect_done succeeded with 02:1a:11:fb:92:fb
root@imx6ulevk:~# restart_wpa_supplicant
+ killall wpa_supplicant
CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
+ sleep 1
CFG80211-ERROR) wl_is_linkdown :
cfg80211: Calling CRDA to update world regulatory domain
Link down Reason : WLC_E_LINK
link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from 02:1a:11:fb:92:fb
+ wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf -D nl80211
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
_dhd_wlfc_mac_entry_update():1649, entry(32)
+ set +x
root@imx6ulevk:~# CFG80211-ERROR) wl_cfg80211_connect : Connecting withff:ff:ff:ff:ff:ff channel (0) ssid "NexusV", len (6)
root@imx6ulevk:~# cat /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
driver_param=/var/run/wlan0
update_config=1
network={
        ssid="NexusV"
        psk="12345678"
root@imx6ulevk:~# wl ver
1.107 RC5.0
root@imx6ulevk:~# wl revinfo
vendorid 0x14e4
deviceid 0x43e2
radiorev 0x3da000
chipnum 0xa9a6
chiprev 0x1
chippackage 0x3
corerev 0x27
boardid 0x726
boardvendor 0x14e4
boardrev P101
driverrev 0x72d2918
ucoderev 0x413080c
bus 0x0
phytype 0xc
phyrev 0x0
anarev 0x0
nvramrev 0
root@imx6ulevk:~# wl status
SSID: "NexusV"
Mode: Managed   RSSI: -52 dBm   SNR: 0 dB       noise: -91 dBm  Flags: RSSI on-channel  Channel: 6
BSSID: 02:1A:11:FB:92:FB        Capability: ESS WEP ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
RSN:
        multicast cipher: AES-CCMP
        unicast ciphers(1): AES-CCMP
        AKM Suites(1): WPA-PSK
        Capabilities(0x000c): No Pre-Auth, Pairwise, 16 PTK Replay Ctrs1 GTK Replay Ctr
HT Capable:
        Chanspec: 2.4GHz channel 6 20MHz (0x1006)
        Primary channel: 6
        HT Capabilities: SGI20
        Supported MCS : [ 0 1 2 3 4 5 6 7 ]
root@imx6ulevk:~# udhcpc -i wlan0
udhcpc (v1.23.1) started
Sending discover...
Sending discover...
Sending select for 192.168.43.41...
Lease of 192.168.43.41 obtained, lease time 3600
RTNETLINK answers: File exists
/etc/udhcpc.d/50default: Adding DNS 192.168.43.1
root@imx6ulevk:~# ping 192.168.43.1
PING 192.168.43.1 (192.168.43.1): 56 data bytes
64 bytes from 192.168.43.1: seq=0 ttl=64 time=66.056 ms
64 bytes from 192.168.43.1: seq=1 ttl=64 time=26.829 ms
64 bytes from 192.168.43.1: seq=2 ttl=64 time=24.099 ms
64 bytes from 192.168.43.1: seq=3 ttl=64 time=21.426 ms
64 bytes from 192.168.43.1: seq=4 ttl=64 time=22.528 ms
^C
--- 192.168.43.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 21.426/32.187/66.056 ms
root@imx6ulevk:~#
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
Contributors
