Valid mode bit pattern for continuous read mode in SEMPER(TM) Quad SPI - KBA233256
ArunKumarChoul
50 questions asked 50 sign-ins 25 sign-ins
Version: **
For continuous SDR Read operations in S25HL/HS-T family, the upper nibble of mode bits  is “A” and the lower nibble of mode bits is “x” (“don’t care”). The S25FL/FS-S family does not support continuous read mode for SDR Fast Read (0Ch). For continuous DDR Quad I/O Read operation, the mode bits must be “A5h” in the S25HL/HS-T, while the S25FL/FS-S family accepts other mode bit patterns where upper and lower nibbles are complementary; for example: 5Ah, F0h.
Following table shows the supported continuous read operations with the valid mode bit patterns:
Operation name
Instruction code
(HEX)
Valid mode bit pattern (HEX) for continuous read operations
S25HL/HS-T
S25FL/FS-S
SDR Fast Read
0C
Ax
Not supported
SDR Dual I/O Read
BB / BC
Ax
Ax
SDR Quad I/O Read
EB / EC
Ax
Ax
DDR Quad I/O Read
ED / EE
A5
Upper and lower nibbles are complementary
