Utilization of Write Buffer when S29GL-T is Configured in x8 (byte) Mode - KBA224466
- Mark as Read
- Printer Friendly Page
Author: AlbertB_56 Version: **
Translation - Japanese: S29GL-Tがx8(バイト)モードで構成されている場合の書き込みバッファの利用 - KBA224466 - Community Translated (JA)
Question:
How is the entire capacity of the Write Buffer utilized on S29GL-T, configured in x8 (byte) mode, when migrating from the S29GL-P or S29GL-S?
Answer:
With Cypress’ Parallel NOR flash memory products, the capacity of the write buffer ranges from 32 bytes for the S29GL064N, to 512 bytes for the S29GL512T. However, for the S29GL-T device, while the size of the write buffer is independent of whether the parallel data lines are configured in x8 (BYTE) mode or in x16 (WORD) mode, the full 512B write buffer can only be written via one write buffer programming command in x16 mode; two write buffer programming commands are required to write 512B to the write buffer when in x8 mode.
The reason for this is that the word count (WC) argument for the “write to buffer” command is one byte – so WC can count to 256 words in x16 mode (that is, the full 512B write buffer capacity), or 256 bytes in x8 mode (that is, only ½ of the 512B write buffer).
Table 1. Command Definitions x16
Command Sequence | Cycles | Bus Cycles | |||||||||||||
First | Second | Third | Fourth | Fifth | Sixth | Seventh | |||||||||
Addr | Data | Addr | Data | Addr | Data | Addr | Data | Addr | Data | Addr | Data | Addr | Data | ||
Read | 1 | RA | RD | ||||||||||||
Reset/ASO Exit | 1 | XXX | F0 | ||||||||||||
Status Register Read | 2 | 555 | 70 | XXX | RD | ||||||||||
Status Register Clear | 1 | 555 | 71 | ||||||||||||
Word Program | 4 | 555 | AA | 2AA | 55 | 555 | A0 | PA | PD | ||||||
Write to Buffer | 6 | 555 | AA | 2AA | 55 | SA | 25 | WC | WBL | PD | WBL | PD | |||
Program Buffer to Flash | 1 | SA | 29 |
Thus, for x8 mode, two write buffer programming operations of 256B each must be used to program the full 512B write buffer: select the starting address align with write buffer offset 0 for the first buffer program operation, and; select the starting address to align with write buffer offset 256 for the second buffer program operation.
- If you are migrating from an older device with smaller write buffers (S29GL-N has a 32B write buffer; S29GL-P has a 64B write buffer), then your existing programming command syntax will work without change if the migration maintains either x8 or x16 mode.
- However, if you are migrating from the prior generation x16-only S29GL-S (≥ 128 Mb) with a 512B write buffer, then keeping the x16 configuration with S29GL-T also means no change to your existing programming command syntax.
- When migrating from the x8/x16 S29GL064S with 256B write buffer to the S29GL-T, then no change to your existing programming command syntax is required if the migration maintains either x8 or x16 mode.
Note that when reading the Common Flash Interface (CFI), as detailed in Table 2, the maximum number of bytes in multi-byte (in x8 BYTE mode) write is 256-bytes (0-255 bytes). The maximum number of words in multi-word (in x16 WORD mode) write is 256-words (0-255 words).
For more details, see the S29GL512T datasheet.
Table 2. CFI Device Geometry Definition
Word Address | Byte Address | Data | Description |
(SA) + 0027h | (SA) + 004Eh | 001Bh (1 Gb) 001Ah (512 Mb) | Device Size = 2N byte; |
(SA) + 0028h | (SA) + 0050h | 0002h | Flash Device Interface Description 0 = x8-only, 1 = x16-only, 2 = x8/x16 capable |
(SA) + 0029h | (SA) + 0052h | 0000h | |
(SA) + 002Ah | (SA) + 0054h | 0009h | Max. number of byte in multi-byte write = 2N (00 = not supported) |
(SA) + 002Bh | (SA) + 0056h | 0000h | |
(SA) + 002Ch | (SA) + 0058h | 0001h | Number of Erase Block Regions within device 1 = Uniform Device, 2 = Boot Device |
(SA) + 002Dh | (SA) + 005Ah | 00XXh | Erase Block Region 1 Information (refer to JEDEC JESD68-01 or JEP137 specifications) 00FFh, 0003h, 0000h, 0002h =1 Gb 00FFh, 0001h, 0000h, 0002h = 512 Mb |
(SA) + 002Eh | (SA) + 005Ch | 000Xh | |
(SA) + 002Fh | (SA) + 005Eh | 0000h | |
(SA) + 0030h | (SA) + 0060h | 000Xh | |
(SA) + 0031h | (SA) + 0062h | 0000h | Erase Block Region 2 Information (refer to CFI publication 100) |
(SA) + 0032h | (SA) + 0064h | 0000h | |
(SA) + 0033h | (SA) + 0066h | 0000h | |
(SA) + 0034h | (SA) + 0068h | 0000h | |
(SA) + 0035h | (SA) + 006Ah | 0000h | Erase Block Region 3 Information (refer to CFI publication 100) |
(SA) + 0036h | (SA) + 006Ch | 0000h | |
(SA) + 0037h | (SA) + 006Eh | 0000h | |
(SA) + 0038h | (SA) + 0070h | 0000h | |
(SA) + 0039h | (SA) + 0072h | 0000h | Erase Block Region 4 Information (refer to CFI publication 100) |
(SA) + 003Ah | (SA) + 0074h | 0000h | |
(SA) + 003Bh | (SA) + 0076h | 0000h | |
(SA) + 003Ch | (SA) + 0078h | 0000h | |
(SA) + 003Dh | (SA) + 007Ah | FFFFh | Reserved |
(SA) + 003Eh | (SA) + 007Ch | FFFFh | |
(SA) + 003Fh | (SA) + 007Eh | FFFFh |
- a25l
- a25lq
- a29
- a290
- a29l
- ac parameters
- active low
- address
- address bus
- adesto
- ale
- amic
- architecture
- async
- at25bcm
- at25df
- at25dl
- at25dn
- at25dq
- at25f
- at26df
- at45db
- bank
- bank address register
- bga
- block
- bottom boot
- buffer
- bulk
- bus
- byte address
- byte mode
- ce
- cfi
- chip
- cle
- clock
- command
- common flash interface
- compatible
- competition
- competitor
- configuration
- configuration register
- control signals
- cs
- current
- cycle
- cypress
- cypress flash memory products
- data
- data bus
- datasheet
- dc parameters
- definitions
- delay
- density
- device id
- dio
- drive
- en25b
- en25f
- en25p
- en25q
- en25qh
- en29gl
- en29lv
- en39sl
- enable
- eon
- erase resolution
- es29lv
- esi
- esmt
- f25l
- f25s
- f49l
- fall time
- floating gate
- gd25q
- gigadevice
- gnd
- ground
- ground bounce
- half-block
- hardware reset
- hex
- high
- hold
- hyperbus
- hyperflash
- hyperram
- input
- interface
- io
- is25cq
- is25ld
- is25lq
- issi
- jr28f
- js28f
- jtag
- jz58f
- k8a
- k8c
- k8d
- k8f
- k8p
- k8q
- latency
- level
- logic
- low
- m25p
- m25pe
- m25px
- m28w
- m29dw
- m29f
- m29w
- m36a
- m36l
- m36w
- m39l
- m58bw
- m58l
- m58w
- macronix
- manufacturers id
- manufacturers part number
- mask opening
- maximum
- mcp
- memory
- micron
- minimum
- mirrorbit
- mode
- mpn
- multi plane
- mx25l
- mx25v
- mx29f
- mx29gl
- mx29lv
- mx29sl
- mx66l
- n25q
- nand
- nor
- oe
- operation
- opn
- ordering part number
- output
- package
- page
- parallel
- parallel nor
- pc28f
- peripheral
- pf38f
- pf48f
- pf58f
- plane
- program
- pz28f
- rc28f
- rd48f
- re
- read
- registers
- replacement
- reset
- rise time
- s26kl128s
- s26kl256s
- s26kl512s
- s26ks128s
- s26ks256s
- s26ks512s
- s27kl0641
- s27ks0641
- s29gl01gp
- s29gl01gs
- s29gl01gt
- s29gl032n
- s29gl064s
- s29gl128p
- s29gl128s
- s29gl256p
- s29gl256s
- s29gl512p
- s29gl512s
- s29gl512t
- s34ml01g1
- s34ml01g2
- s34ml02g1
- s34ml02g2
- s34ml04g1
- s34ml04g2
- s34ml08g1
- s34ml08g2
- s34ml16g2
- s34ms01g2
- s34ms02g2
- s34ms04g2
- s34ms08g2
- s34ms16g2
- s34sl01g2
- s34sl02g2
- s34sl04g2
- s70fl01gs
- s70fs01gs
- s98
- s99-
- samsung
- sck
- sclk
- sector
- sector block
- sector erase
- serial
- serial nor
- set
- signal level
- simultaneous
- single level cell
- size
- slc
- slc nand
- software reset
- soic
- solder ball
- spansion
- spare area
- sphere
- state
- status
- status register
- subsector
- tc58nvg2s0hbai4
- te28f
- technology
- timing
- top boot
- toshiba
- tsop
- typical
- uniform
- uson
- vcc
- vih
- vil
- vio
- voh
- vol
- voltage
- vss
- w25q
- w25x
- w29gl
- winbond
- word address
- word mode
- wp
- write buffer
- wson
