Using TLE94112ES/TLE94112EL evaluation boards
Infineon_Team
Please find the quick start guidance and more detailed information for these board on the websites:
- TLE94112ES_RPI_HAT (Easy-to-use DC Motor Control HAT equipped with TLE94112ES and TLS4125D0EP V50)
- TLE94112EL_SHIELD (DC Motor Shield with TLE94112EL for Arduino)
You can find all the hardware and software required in order to use the respective board and a quick guide to installing the required software.
