Using MLC (Multiple-Level Cell) Flash Nand with NX2LP
Question: Can we use MLC (Multiple-Level Cell) Flash Nand with NX2LP?
Answer:
NX2LP does not support MLC Flash Devices. The NX2LP has 1-bit ECC correction per 256-byte, which will not be able to handle MLC NAND. The MLC NAND requires 4-bit ECC correction.
Contributors
