USB to SD throughput with EZ-USB™ FX3S, EZ-USB™ SD3, or EZ-USB™ SD2 - KBA233245
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Version: *A
For each storage port, the theoretical data rate at which data will be transferred can be calculated as follows:
Data rate (MBps): SD_CLK frequency * data bus width/8
  • SD_CLK frequency: Frequency of output clock (storage port)
  • Data bus width: Storage port bus width
Table 1 shows the conditions required for maximum throughput.
Table 1    Requirements for maximum throughput
Sr no.
 Item
 Details
1
Device used for testing
FX3S
2
SD card
SanDisk SD1N5C4 eMMC 4.41
3
SD bus width
8 bits
4
MMC clock frequency
52 MHz (DDR mode)
5
Driver
Windows mass storage device
Table 2     USB - SD card performance
USB speed
Read (MBps)
Write (MBps)
USB 3.0
44.5
49.6
USB 2.0
30.2
24.1
The standard Windows mass storage driver uses tiny bursts (64 KB) for mass storage data transfers, and the performance obtained is limited by various protocol overheads.
For the performance of EZ-USB™ FX3S with RAID 1 firmware, see section 8 of AN89661.
