Default VID and PID for USB-Serial Interface
- Mark as Read
- Printer Friendly Page
Community Translation: USB-シリアル: サイプレスのデフォルト VID および PID – KBA89355
Can I use a PID of my choice with Infineon VID?
The simple answer is no. If you are using Infineon VID (0x04B4), you may not use any random PIDs. The USB-Serial Configuration Utility will allow you to use only the default PID based on the part number and the SCB configurations, as listed below:
Part Number |
SCB 0 |
SCB 1 |
PID |
Mode |
Protocol |
Mode |
Protocol |
1 |
CY7C65211-24LTXI |
UART |
CDC |
NA |
NA |
0x0002 |
UART/SPI/I2C |
Vendor/PHDC |
NA |
NA |
0x0004 |
2 |
CY7C65213-32LTXI |
UART |
CDC |
NA |
NA |
0x0003 |
UART |
Vendor/PHDC |
NA |
NA |
0x0006 |
3 |
CY7C65215-32LTXI |
UART |
CDC |
UART |
CDC |
0x0005 |
UART |
CDC |
UART/SPI/ I2C/JTAG |
Vendor/PHDC |
0x0007 |
UART/SPI/I2C |
Vendor/PHDC |
UART |
CDC |
0x0009 |
UART/SPI/I2C |
Vendor/PHDC |
Vendor/PHDC |
0x000A |
If you are not using the Infineon VID, then the USB-Serial Configuration Utility will allow you to use any PID.
