05:02 AM
- Mark as Read
- Printer Friendly Page
Feb 15, 2021
05:02 AM
Traveo II Automotive Body Controller - FAQ – DMA - KBA232509
Home Page: Traveo II Automotive Body Controller - FAQ – CDC -... - Cypress Developer Community
9. DMA
9.1. Is it possible to configure a P-DMA channel (for instance, P-DMA0), while the P-DMA peripheral is enabled globally? Should the P-DMA instance be globally disabled before configuring a particular channel?
There is no need to disable the P-DMA peripheral globally. You can disable that channel. However, make sure that there is no trigger with invalid channel configuration when the channel is being configured or reconfigured.
Labels
Rate this article:
