Knowledge Base Articles
Thermal Characteristics for SMPTE HOTLink - CY7B9235/CY7B9335
Answer: Title:
Questions:
- How do I calculate case temperature?
- How do I calculate board temperature?
- What is the maximum ambient temperature for HOTlink?
- What are the Theta-JA and Theta-JC values?
- What is the maximum junction temperature, Tj?
Response:
Because the thermal characteristics are dependent on the ambient temperature and power used by the system, both the equations and values are provided below.
Tj = Junction temperature
Tb = Board temperature
Ta = Ambient temperature
Tc = Case temperature
Theta-Ja = Junction to ambient thermal resistance
Theta-Jb = Junction to board thermal resistance
Theta-Jc = Junction to case thermal resistance
Pd = Power used by the device.
TEMPERATURE RANGES:
Commercial: Ta = 0 to 70 °C
Industrial: Ta= -40 to 85 °C
KNOWN VALUES
These are gotten from the table below.
JUNCTION TEMPERATURE
Tj = Theta-Ja*Power   Ta (1)
BOARD TEMPERATURE
Tj = Theta-Jb*Power   Tb (2)
so Tb = Tj - Theta-Jb*Power (3)
>From Eq(1) and (3) we get
Tb = (Theta-Ja - Theta-Jb)*Power   Ta (4)
CASE TEMPERATURE
Tc = Tj - Theta-Jc*Pd (5)
so Tc = (Theta-JA - Theta-JC)*Power   Ta (6)
CY7B9235/CY7B9335 Thermal Values
 CY7B9235CY7B9335
Part Number - Theta-JA (°C/W)Theta-JC (°C/W)Tj (°C)Theta-JA (°C/W)Theta-JC (°C/)WTj (°C)
270JC271591.6245104.8
400JC271591.6245104.8
Useful Link:
CY7C9235 SMPTE-259M/DVB-ASI Scrambler/Controller (http://www.cypress.com/?rID=14213)
CY7C9335 SMPTE-259M/DVB-ASI Descrambler/Framer-Controller (http://www.cypress.com/?rID=14214)
Keywords:
HOTLink, SMPTE, CY7B9235, CY7B9335, thermal characteristics, Theta-JA, Theta-JB, Theta-JC, junction, temperature, Tj, case, board, Ta, Tb, Tc.
Version history
Revision #:
1 of 1
Last update:
‎May 19, 2009 06:16 AM
Updated by:
Contributors
