The difference of USB Power Delivery power supply types
Kieran_Pan
250 sign-ins 10 likes received First question asked
Question
What is the difference of USB Power Delivery power supply types?
Answer
Based on Type-C Power Delivery specification, there are five difference Power Data Objects (PDOs) for demonstrating USB PD power supply types:
PDO
Description
Fixed Supply PDO
Fixed Supply PDO voltage have to 5V, 9V, 15V, 20V, 28V, 36V, and 48V. Current limits to rang of 0A – 5A. Source shall support at least one fixed supply PDO which have the capability of operating at 5V.
Variable Supply(no-Battery) PDO
Variable Supply (non-Battery) PDO represents that very poorly regulated sources. The absolute voltage, including any voltage variation, shall not fall below the minimum voltage and shall not exceed the maximum voltage. The minimum voltage shall not be less than 80% of the maximum voltage.
Battery Supply PDO
Battery Supply PDO represents that batteries can be connected directly as a source to VBUS. Maximum and minimum voltage in 50mV units and the maximum allowable power in 250mW units in Battery Supply PDO Message.
SPR PPS
(Programmable Power Supply)
APDO
The PPS APDO represents a source whose output can be programmatically controlled in the advertised voltage range. It has a programmable output current fold back. The output voltage range is adjustable in 20mV steps. Voltage range is 3.3V - 21V. Current limits to rang of 0A – 5A.
EPR AVS
(Adjustable Voltage Supply)
APDO
EPR AVS APDO doesn’t support current limit. AVS APDO is limited by the power. It can set that power PD POWER(PDP) in the the capabilities message. The output voltage range is adjustable in 100mV steps. Voltage range is 15V - 48V.
