The Measured Current Is Smaller Than Set in the CapSense® User Modules and IDACL_D/IDACR_D Registers – KBA92751
01:08 AM
- Mark as Read
- Printer Friendly Page
Jun 09, 2014
01:08 AM
Version: **
Question: The measured current is smaller than the current set in the CapSense® User Modules and IDACL_D/IDACR_D registers on the CY8C21x45, CY8C22x45, and CY8C28xxx devices. What is the reason for this and what is the workaround?
Answer:
The PSoC® 1 iDACs are not trimmed by default. To get correct iDAC values, the iDACs should be trimmed. Use the following command to trim the iDACs:
DAC_CR1 |= 0x10;
The command should be executed before the CapSense_Start API. The trimming operates correctly because the CapSense User Modules do not change the IDAC_TRIM bitfields of the IDAC_CR1 register.
Labels
Rate this article:
Contributors
This widget could not be displayed.Anonymous
