TRAVEO™ T2G MCU: Pin assignment support tool – KBA237998
Infineon_Team
Question: How do I document and share information about TRAVEO™ T2G pin assignments for developing ECU boards?
Answer:
In TRAVEO™ T2G, you get the pin assignment support tool as an Excel file that supports:
  • Select the function of each pin (you can also check for duplication of selected pin functions)
  • Display the status of the used channel from the selected pin function
  • Display the selected pin layout graphically
Figure 1, Figure 2, and Figure 3 show the operation of the pin assignment support tool, TRAVEO™ T2G family.
Figure 1 Selecting the pin function
 Figure 2 Displaying the status of the used channel
Figure 3 Displaying the selected pin diagram
Download the Excel sheet from https://www.infineon.com/cms/en/product/microcontroller/32-bit-traveo-t2g-arm-cortex-microcontroller....
name: /Pin assign support tool, TRAVEO™ T2G family/
Figure 4 Download pin assignment support tool, TRAVEO™ T2G family
Note: This KBA applies to the following series of TRAVEO™ T2G MCU:
  • TRAVEO™ T2G series
