TRAVEO™ T2G MCU: LBO and IBO performance on internal and external memory – KBA235809
1000 replies posted First like given 750 replies posted
IFX_Publisher2
Version: **
This KBA presents the results of performance measurements performed on different combinations of locations of source and store buffers using image-based rendering mode (IBO) and line-based rendering mode (LBO).
Software environment used:
  • Green Hills MULTI 2017.14
  • TRAVEO™ T2G graphics driver v1e.1.0
Reference documents:
  • 002-27763: CYT3DL datasheet
  • 002-25454: Graphics Driver for TRAVEO(TM) T2G Cluster Series User Guide
Software setup:
Figure 1 is a sample image used as the source surface for blitting. The image resolution is 400x480 PPI. Depending on the store and source surfaces configuration, this image is stored in either Video RAM (VRAM), HYPERRAM™, or HYPERFLASH™.
The color format of both source and store surface is chosen as R8G8B8A8.
Every result is recorded over a blit of 300 iterations.
Figure 1   Source image taken for blit (400x480)
Figure 2   Software flow
Table 1 shows the surface configurations used.
Table 1  Timing results captured for different source and store combination
Source surface location
Store surface location
Internal flash
VRAM
VRAM
VRAM
VRAM
HYPERRAM™ / External RAM
HYPERRAM™
VRAM
HYPERRAM™
HYPERRAM™
HYPER FLASH™
VRAM
Table 2  External memory configurations
S26H (HYPERFLASH™)
S27K (HYPERRAM™)
PLL400#2 (HF8): 200 MHz
PLL400#3 (HF9): 200 MHz
SMIF clock: 100 MHz
SMIF Clock: 100 MHz
Setup delay: 3 clock cycles
Hold delay: 3 clock cycles
Hold delay: 1 clock cycles
Mode: XIP
Mode: XIP
Read latency code: 20
Read latency code: 4
Merge enable with timeout after 4096 cycles
Timing results:
Table 3  Internal flash to VRAM
Megapixels per second
LBO/IBO
IBO
240.9
963.7
LBO
205.73
822.94
0.85
Table 4  VRAM to VRAM
LBO/IBO
IBO
218.85
875.40
LBO
543.87
2127.5
2.5
Table 5   VRAM to HYPERRAM™
LBO/IBO
IBO
32.77
131.10
LBO
515.79
2063.16
15.73
Table 6   HYPERRAM™ to VRAM
LBO/IBO
IBO
48.9
195.66
LBO
36.76
147.07
0.75
Table 7  HYPERRAM™ to HYPERRAM™
LBO/IBO
IBO
15.26
61.069
LBO
36.6
146.38
2.4
Table 8   HYPERFLASH™ to VRAM
LBO/IBO
IBO
48.87
195.48
LBO
32.4
129.7
0.66
Notes:
  • Memory Bandwidth reducing LBO performance: Memories other than VRAM can transfer only less than or equal to 32 bits in one clock cycle. In additional, in LBO mode three fetches may happen at different locations in memory which can create additional overhead of non-sequential memory access for external memories. Hence LBO is even slower compared with IBO when all the source images are in external memories (e.g.: internal flash). The performance LBO/IBO becomes better if you use smaller bits per pixel (BPP) sources.
  • For example, if you compare for blending to target HRAM, LBO/IBO ratio is larger than factor 3. This is because blending of multiple single images requires to read and write the target buffer for each single blit. LBO blends all images in internal buffer together and writes the result only one time.
  • When using LBO, disabling Object Partitioning may sometimes make the blit a little faster.
Note:     This KBA applies to the following series of TRAVEO™ MCUs:
TRAVEO™ T2G Cluster CYT3DL series
