TRAVEO™ T2G MCU: JTAG pin configuration after reset and how to avoid undesired consumption current in DeepSleep mode
Niimi
10 sign-ins 5 sign-ins First question asked
This KBA explains JTAG pin configuration after reset and how to avoid undesired consumption current in DeepSleep mode in TRAVEO™ T2G MCU.
TRAVEO T2G supports JTAG and SWD protocol. By default, the JTAG mode is selected on a power-up reset and the JTAG protocol can be used.
After reset, JTAG pin are configured as below during boot process.
Pin Name
Input Enable
Drive Mode
swj_trstn
Yes
Internal Pull-up
swj_swo_tdo
Yes
Strong(output)
swj_swdoe_tdi
Yes
Internal Pull-up
swj_swdio_tms
Yes
Internal Pull-up
swj_wsclk_tclk
Yes
Internal Pull-down
“swj_swo_tdo” pin is configured as input enabled and Strong output. According to DAP specification, output of this pin is high-z while DAP is idle.
This might result in leak current from “swj_swo_tdo” pin power source, e.g. VDDD in CYT2xx series, though input buffer. Please re-configure input buffer of this pin from enabled to disabled to avoid unwanted power consumption in low power mode, especially DeepSleep mode.
e.g. relating register of CYT2B9:
GPIO_PRT23_CFG.IN_EN4 = 0u // input buffer disable
More information
  • TRAVEO™ T2G Architecture TRM
  • TRAVEO™ T2G Register TRM
  • TRAVEO™ T2G Application Note
Note:
This KBA applies to the following series of TRAVEO™ T2G MCUs:
  • TRAVEO™ T2G CYT2xx series
  • TRAVEO™ T2G CYT3xx series
  • TRAVEO™ T2G CYT4xx series
  • TRAVEO™ T2G CYT6xx series
