TRAVEO™ T2G MCU: Debug interface pin setting – KBA236293
Infineon_Team
Community Translation: TRAVEO™ T2G マイコン: デバッグ・インターフェイスのピン設定 – KBA236293
Version: **
After reset, the debug pins remain in a high-impedance (High-Z) state, and after the boot process, the debug pins are configured as follows:
Pin name
Input enable
Drive mode
swj_trstn
Yes
Internal pull-up
swj_swo_tdo
Yes
Strong (output)
swj_swdoe_tdi
Yes
Internal pull-up
swj_swdio_tms
Yes
Internal pull-up
swj_swclk_tclk
Yes
Internal pull-down
Note: For the swj_swo_tdo pin, the user application should either disable the input buffer or keep it enabled with the TDO line controlled through pull-up/pull-down. In general, an enabled input buffer for a floating line can draw a higher current.
Note: The debug access port pin may not be set in the boot process depending on the debug access port configuration in access restriction. For more details, see the application note AN228680 - Secure system configuration in TRAVEO™ T2G family.
Note: This KBA applies to the following series of TRAVEO™ T2G MCUs:
  • TRAVEO™ T2G CYT2 series
  • TRAVEO™ T2G CYT3 series
  • TRAVEO™ T2G CYT4 series
