TRAVEO™ T2G MCU: Damage to PMIC enable pin – KBA237578
Infineon_Team
Community Translation: TRAVEO™ T2G MCU: PMICイネーブル端子の損傷 – KBA237578
Compared to a standard GPIO pin, the absolute maximum drive current (SID23A/B) is extremely limited in the PMIC enable pin. Depending on the external PMIC, a series resistor might be needed to limit the current; otherwise, the pin might get damaged permanently. For electrical specifications, see the device datasheet.
Note: This KBA applies to the following TRAVEO™ T2G MCUs:
  • CYT3 series
  • CYT4 series
