TRAVEO™ T2G: Guidelines for exposed pad – KBA236264
06:54 AM
- Mark as Read
- Printer Friendly Page
Sep 23, 2022
06:54 AM
Community Translation: TRAVEO™ T2G: エクスポーズドパッドのガイドライン – KBA236264
Version: **
When mounting the MCU on the board, connect the exposed pad to the ground. The exposed pad is isolated with an epoxy to the substrate of the die, making it an excellent path to remove heat from the IC. Never connect to other signals.
Note: This KBA applies to the following series of TRAVEO™ T2G MCUs:
- CYT2 series
- CYT3 series
- CYT4 series
Labels
Rate this article:
