TLE984x, Switch shuts down when Vs undervoltage bit sets
Infineon_Team
The shut down feature is designed by Infineon to protect the high side load. To enable the high-side switch again, clear the Vs undervoltage bit or to make high-side switch work in Vs undervoltage, enable the high-side switch cyclic sense feature.
