TLE92104,TLE92108: Is Charge pump still working in case of fault condition
IFX_Publisher2
1000 replies posted First like given 750 replies posted
Community Translation: TLE92104,TLE92108: フォルト状態の場合でもチャージポンプはまだ動作しますか?
In case of a fault on a half-bridge driven by the device, the charge pump of the device continues working and supplying other half-bridges that are ON.
The only conditions which deactivate the charge pump are:
- Overvoltage on the supply voltage
- Undervoltage on the supply voltage
- Under voltage on the CP pin caused by the thermal shutdown
