TLE92104: Do charge pumps still work when there is a fault?
May 26, 2022
05:36 AM
- Mark as Read
- Printer Friendly Page
May 26, 2022
05:36 AM
Community Translation: TLE92104: フォルトが発生してもチャージポンプはまだ動作しますか?
In case of a fault on a half-bridge driven by the device, the charge pump of the device continues working and supplying other half-bridges that are ON.
The only conditions which deactivate the charge pump are:
1. Overvoltage on the supply voltage
2. Under voltage on the supply voltage
3. Under voltage on the CP pin caused by the thermal shutdown
Labels
Rate this article:
