TLE493D-W2B6 compatibility.
IFX_Publisher2
First like given 750 replies posted 250 sign-ins
Question:
Is it possible to easily replace the TLE493D-W2B6 by TLE493D-A2B6 or TLE493D-P2B6?
Solution:
The TLE493D-W2B6 can be replaced with the TLE493D-P2B6.
Replacing the TLE493D-W2B6 with the TLE493D-A2B6 requires careful evaluation. Several features are not available (e.g. functional safety support or wake up) and the firmware might be affected by small changes.
(find the details in the slide set TLE493DW2B6_replacement_isolar.pdf attached)
