TLE493D-W2B6 2Go kit used to measure Earth magnetic field
IFX_Publisher2
1000 replies posted First like given 750 replies posted
The Earth magnetic field is about 50 µT. The TLE493D is designed for position sensing with a permanent magnet and measures a magnetic field up to 160mT. Due to the difference in resolution the Earth mangetic field can not be measured with sufficient resolution.
