Knowledge Base Articles
Supporting ACA-Dock Feature in Smartphone and Tablet Docks with HX3 USB 3.0 Hub Controller - KBA96321
Question: The ACA-Dock feature enables charging and simultaneous data transfer on BC v1.2 compliant OTG Host Smartphones and Tablets connected to the upstream port of HX3.
Answer:
This Knowledge base (KB) article introduces the ACA-Dock feature and describes the system requirements to support ACA-Dock. This article also introduces the HX3 and PSoC 4 based ACA-Dock Solution and lists the Smartphones and Tablets proven to work on HX3.
Version history
Revision #:
1 of 1
Last update:
‎Feb 17, 2015 03:22 AM
Updated by:
Contributors
