Stress on Cypress Parallel NOR Flash When Input Control Signals Are Floating/Tristated - KBA203615
04:55 AM
- Mark as Read
- Printer Friendly Page
Sep 28, 2015
04:55 AM
Version: *A
Translation - Japanese: CypressパラレルNOR Flash Memoryの入力制御信号がフローティング / Tri-State状態の場合の負荷 - KBA203615 - Community Translated (J...
Question:
Are Cypress Parallel NOR Flash products under any stress with input control signals floating/tri-stated?
Answer:
No. Cypress Parallel NOR FLASH products are not functional or selected when VCC is applied and input control signals are floating. However, there may be the possibility of a standby current consumption of~5 µA or less. Keep in mind that no accurate power consumption measurement exists with only VCC applied and input control signals floating. It is a best practice to not leave any input control signals floating.
Labels
- a25l
- a25lq
- a29
- a290
- a29l
- ac parameters
- adesto
- amic
- at25bcm
- at25df
- at25dl
- at25dn
- at25dq
- at25f
- at26df
- at45db
- competitor
- consumption
- current
- cypress
- dc parameters
- decoupling
- density
- en25b
- en25f
- en25p
- en25q
- en25qh
- en29gl
- en29lv
- en39sl
- eon
- es29lv
- esi
- esmt
- f25l
- f25s
- f49l
- failure
- float
- floating
- floating gate
- functional
- gd25q
- gigadevice
- hard error
- input
- input control signal
- is25cq
- is25ld
- is25lq
- issi
- jr28f
- js28f
- jz58f
- k8a
- k8c
- k8d
- k8f
- k8p
- k8q
- m25p
- m25pe
- m25px
- m28w
- m29dw
- m29f
- m29w
- m36a
- m36l
- m36w
- m39l
- m58bw
- m58l
- m58w
- macronix
- memory
- micron
- mirrorbit
- mx25l
- mx25v
- mx29f
- mx29gl
- mx29lv
- mx29sl
- mx66l
- n25q
- nor flash memory
- output
- parallel nor
- pc28f
- pf38f
- pf48f
- pf58f
- power
- process technology
- pz28f
- rc28f
- rd48f
- reset
- s25fl064l
- s25fl116k
- s25fl127s
- s25fl128l
- s25fl132k
- s25fl164k
- s25fl256l
- s25fl256s
- s25fl512s
- s25fs064s
- s25fs128s
- s25fs256s
- s25fs512s
- s25fs512t
- s26kl128s
- s26kl256s
- s26kl512s
- s26ks128s
- s26ks256s
- s26ks512s
- s27kl0641
- s27ks0641
- s29al008j
- s29al016j
- s29as008j
- s29as016j
- s29gl01gp
- s29gl01gs
- s29gl01gt
- s29gl032n
- s29gl064s
- s29gl128p
- s29gl128s s29gl256s
- s29gl256p
- s29gl512p
- s29gl512s
- s29gl512t
- s29jl032j
- s29jl064j
- s29pl032j
- s29pl064j
- s34ml01g2
- s34ml02g2
- s34ml04g2
- s34ml08g2
- s34ml16g2
- s34ms01g2
- s34ms02g2
- s34ms04g2
- s34ms08g2
- s34ms16g2
- s70fl01gs
- s70fs01gs
- s98
- s99-
- samsung
- soft error
- spansion
- standby
- stress
- tc58nvg2s0hbai4
- te28f
- technology node
- toshiba
- tri-stated
- vcc
- vio
- voltage
- w25q
- w25x
- w29gl
- winbond
Rate this article:
Contributors
This widget could not be displayed.Anonymous
