Some Cypress Flash Devices Provide VIO. What if VCC and VIO come from Different Supplies? - KBA203733
11:32 PM
- Mark as Read
- Printer Friendly Page
Oct 11, 2015
11:32 PM
Version: *A
Translation - Japanese: いくつかのCypress Flash Memoryは電源電圧コアVCCとは別にIO電圧VIOオプションを持つ製品があります。 そのVCCとVIOを別の電圧レベルで供給する場合に気にかけておく点はありま...
Question:
Some Cypress Flash devices provide the VIO option in addition to the VCC core voltage. What if VCC and VIO have separate supplies?
Answer:
In this case, the VIO and VCC supplies must comply with the power-up and power-down requirements defined in the datasheet. For the GL-S flash, VCC must be greater than VIO by at least 200 mV during the power-up ramp, until both voltages are no less than the minimum operating voltage.
Labels
- a25l
- a25lq
- a29
- a290
- a29l
- ac parameters
- active low
- address
- ale
- amic
- at25bcm
- at25df
- at25dl
- at25dn
- at25dq
- at25f
- at26df
- at45db
- bus
- can
- ce
- cle
- clock
- competitor
- control signals
- core voltage
- cs
- current
- cypress flash memory products
- data
- dc parameters
- dio
- drive
- en25b
- en25f
- en25p
- en25q
- en25qh
- en29gl
- en29lv
- en39sl
- enable
- es29lv
- esi
- esmt
- f25l
- f25s
- f49l
- fall time
- flash
- gd25q
- gigadevice
- gnd
- ground
- ground bounce
- hardware reset
- high
- hold
- hyperbus
- hyperflash
- hyperram
- i2c
- initialization
- input
- interface
- io
- is25cq
- is25ld
- is25lq
- issi
- jr28f
- js28f
- jz58f
- k8a
- k8c
- k8d
- k8f
- k8p
- k8q eon
- level
- logic
- low
- m25p
- m25pe
- m25px
- m28w
- m29dw
- m29f
- m29w
- m36a
- m36l
- m36w
- m39l
- m58bw
- m58l
- m58w
- macronix
- maximum
- memory
- micron
- minimum
- mx25l
- mx25v
- mx29f
- mx29gl
- mx29lv
- mx29sl
- mx66l
- n25q
- nor flash memory
- oe
- output
- parallel
- parallel nor
- pc28f
- peripheral
- pf38f
- pf48f
- pf58f
- pnor
- power-up
- pz28f
- rc28f
- rd48f
- re
- reset
- rise time
- s25fl064l
- s25fl116k
- s25fl127s
- s25fl128l
- s25fl132k
- s25fl164k
- s25fl256l
- s25fl256s
- s25fl512s
- s25fs064s
- s25fs128s
- s25fs256s
- s25fs512s
- s25fs512t
- s29al008j
- s29al016j
- s29as008j
- s29as016j
- s29gl01gp
- s29gl01gs
- s29gl01gt
- s29gl032n
- s29gl064s
- s29gl128p
- s29gl128s s29gl256s
- s29gl256p
- s29gl512p
- s29gl512s
- s29gl512t
- s29jl032j
- s29jl064j
- s29pl032j
- s29pl064j
- s70fl01gs
- s70fs01gs
- s98
- s99-
- samsung
- sck
- sclk
- serial
- serial nor
- signal level
- slc nand
- snor
- spi
- state
- tc58nvg2s0hbai4
- te28f
- timing
- toshiba
- typical
- vcc
- vih
- vil
- vio
- voh
- vol
- voltage
- vss
- w25q
- w25x
- w29gl
- winbond
- wp
Rate this article:
Contributors
This widget could not be displayed.Anonymous
