Significance of RSSI
saiprashanthc_
Question: What is the significance of RSSI in CYRF6936?
Answer:
RSSI value is the RF strength of the environment surrounding the device (CYRF6936). This value actually depends on the all the wireless devices working at that time.  If there is another external device working on the same channel of ISM then also the RSSI value increases.
Contributors
