Sensor Dimensions of CY8CMBR3xxx CapSense® Express™ Devices
How to find out the dimensions of a sensor that you want to use in the design?
- You can use the Design Tool Box available in the EZ-Click™ Customizer tool to determine the dimensions of the sensor.
In addition to this tool, you can refer to the CapSense® Getting Started Guide and other CY8CMBR3xxx Design Guide documents that have detailed and complete design guidelines for sensors, layout, and system design.
Version: **
Translation - Japanese:CY8CMBR3xxx CapSense® エクスプレス デバイスのセンサー寸法 - KBA90795 - Community Translated (JA)
