SEMPER™ and S25FS-S flash memory devices register group structure vs standard memory products - KBA236397
Infineon_Team
In previous flash generations, the register groups were a combination of nonvolatile, volatile, and OTP bits. The recent memory products, such as SEMPER™ and the S25FS-S family, have independent nonvolatile and volatile memory register cell groups. The following table compares the register structures between the flash memory families.
Table 1 Status Registers and Configuration Registers comparison table
Recently developed flash memory family (SEMPER™ and S25FS-S)
Previous generation flash memory family
Device Status
Status Register 1
STR1N[7:0], STR1V[7:0]
Status Register 1
SR1[7:0]
Status Register2
STR2V[7:0]
Status Register2
SR2[7:0]
Device Configuration
Configuration Register 1
CFR1N[7:0], CFR1V[7:0]
CR1[7:0]
Configuration Register 2
CFR2N[7:0], CFR2V[7:0]
Configuration Register 3
CFR3N[7:0], CFR3V[7:0]
Configuration Register 4
CFR4N[7:0], CFR4V[7:0]
  • STRxN: Nonvolatile status registers
  • STRxV: Volatile status registers
  • CFRxN: Nonvolatile configuration registers
  • CFRxV: Volatile configuration registers
To access the new independent register groups, RDAR(65h)/WRAR(71h)/WRENV(50h) commands must be used with the addresses.
With the previous RDSR (05h Read Status Register) and RDCR (35h Read Configuration Register), users could only access a limited part of the registers resulting in limited features to operate flash.
The following table details the different supported commands for register access.
Table 2 Register related commands comparison
Related Commands
RDAR(65h)
RDSR1(05h)
RDSR2(07h)
RDCR(35h)
Read Any Register
Read Status Register-1
Read Status Register-2
Read Configuration Register-1
RDSR1(05h)
RDSR2(07h)
RDCR(35h)
ReadgStatus Register-2
WRAR(71h)
WRR(01h)
Write Any Register
Write Register (Status-1, Configuration-1)
WRR(01h)
WRENV(50h)
WREN(06h)
Write Enable Volatile
Write Enable
WREN(06h)
Write Enable
Read Any Register(65h) and Write Any Register(71h) are commands with address. Using the provided address table in each device’s datasheet, the user can read from or write to any nonvolatile and volatile registers.
Figure 1 Read Any Register Read Command Sequence
Figure 2 Write Any Register Command Sequence
