SEMPER™ NOR Flash: Using Sector Erase Count transaction – KBA238291
Infineon_Team
Infineon SEMPER™ NOR Flash family supports the Sector Erase Count transaction that allows users to know the number of erase cycles on an addressed sector. Once the Sector Erase Count command is issued, the device enters a busy state until the erase cycle count information is stored in the Sector Erase Count Register (SECV).
The SECV is a volatile register with a 3-byte (or 24-bit) width. Table 1 shows the definition of Sector Erase Count Register bits. The SECV[22:0] bits denote the number of erase cycles, and the SECV[23] is a flag that shows whether the reported erase cycle count is valid or corrupted.
Table 1 Sector Erase Count register
Bit number
Name
Function
Factory default
Description
SECV[23]
SECCPT
Sector Erase Count Corruption Status Flag
0x0
The SECCPT bit is used to determine if the reported sector erase count is corrupted and has been reset.
Note that if SECCPT is set due to count corruption, it will reset to 0 on the next successful erase operation on the selected sector.
Selection Options:
0 = Sector Erase Count is not corrupted and is valid
1 = Sector Erase Count is corrupted and is not valid
SECV[22:0]
SECVAL[22:0]
Sector Erase Count Value
0x000000
The SECVAL[22:0] bits store the number of times a sector has been erased.
Table 2 shows the register address map for each byte of SECV.
Table 2 Sector Erase Count register address map
Register type
Reigster name
Register address (Hex)
Sector Erase Count Register [7:0]
SECV[7:0]
&&800091
Sector Erase Count Register [15:8]
SECV[15:8]
&&800092
Sector Erase Count Register [23:16]
SECV[23:16]
&&800093
Note: “&&” is the address of the selected die
Figure 1 shows the transaction for the sequence getting the erase cycle count for one sector. Repeat this flow with different sector addresses to get the erase cycle count for multiple sectors.
Figure 1 Sector Erase Count transaction sequence
Note that the SECV[22:0] stores the number of erase cycles of the logical sector that the Endura Flex algorithm maps to the physical sector. The logical sector-to-physical sector mapping changes if the sectors belong to higher endurance regions. To monitor and maintain erase cycles on physical sectors, configure the region as long retention, where the logical sector to physical sector mapping is never changed.
