S6BT112A CXPI Transceiver: Terminal Output at Mode Transition - KBA224569
11:27 PM
- Mark as Read
- Printer Friendly Page
Sep 19, 2018
11:27 PM
Author: SHUS Version: **
Translation - Japanese: S6BT112A CXPIトランシーバー:モード遷移時の端子出力 - KBA224569 - Community Translated (JA)
Question:
When changing the input level of the NSLP pin from "L" to "H" (Sleep mode -> Normal mode), what is output to the BUS and RXD pins?
Answer:
This is the standby state during the Normal mode after releasing the Sleep mode. During this state, CLK (in slave node), the RXD pin, and the BUS pin enter the high-impedance state. After "TMODE_CHG” time elapses, this state changes to the Normal mode. For details, refer to the "Standby Mode" sections in the datasheet from the following link.
Labels
Rate this article:
