S6BT112A CXPI Transceiver: How to Apply SSCG Function – KBA229362
ChaitanyaV_61
50 questions asked 25 likes received 25 sign-ins
Author: SadaharuK_26          Version: **
To apply SSCG function in CXPI system, S6BT112A01 must be in the master node.
According to CXPI protocol, the BUS clock is provided only by the master node (Refer to JASO D 015-3 for detail). The SSCG function in S6Bt112A01 is to add fine modulation to the BUS clock to reduce EMI noise. To apply SSCG function in CXPI system, the proper usage of S6BT112A family is shown in Table 1.
Table 1. Apply SSCG function in CXPI system
Part number
With SSCG function
CXPI node Applied
S6BT112A01
Yes
Master node
S6BT112A02
No
Slave node
Contributors
