S6BT112A CXPI Transceiver: CLK Pin Output for Slave Node - KBA223645
Community-Team
50 questions asked 10 questions asked 5 questions asked
Version: **
Translation - Japanese: S6BT112A CXPIトランシーバー:スレーブノードのCLKピン出力 - KBA223645- Community Translated (JA)
Question:
When using the S6BT112A CXPI Transceiver in Slave node (normal mode), what is the output to the CLK pin?
Answer:
The clock on the CXPI communication bus is output to the CLK pin. The bit rate of the CXPI communication bus can be determined by measuring this clock.
Contributors
