Knowledge Base Articles
S6BT112A CXPI Transceiver: CBUS Range – KBA229274
ChaitanyaV_61
Author: SadaharuK_26           Version: **
Question:
What is the range of CBUS for the following figure (CXPI BUS Load Connection mentioned in S6BT112A datasheet)?
Answer:
The range of CBUS (System capacity), CMASTER (Master node capacity), and CSLAVE (Slave node capacity) are listed in Table 1. For details, see JASO D 015-3.
Table 1. CBUS Range
Item
MIN
TYP
MAX
Unit
Explanation
CBUS
1
4
10
nF
Capacity of system including all nodes and communication bus.
CMASTER
220
pF
Capacity of master node including ECU connector.
CSLAVE
220
250
pF
Capacity of slave node including ECU connector.
Version history
Revision #:
1 of 1
Last update:
‎Jan 15, 2020 10:36 PM
Updated by:
Contributors
