Knowledge Base Articles
Resources Available in Power Modes in PSoC 4 and PSoC 6 MCU - KBA229035
ChaitanyaV_61
Author: LinglingG_46         Version: *A
Translation - Japanese: PSoC 4 および PSoC 6の異なる電力モードで利用可能なリソース - KBA229035 - Community Translated (JA)
PSoC 4 Family:
PSoC 4 features five power modes of operation, which include Active, Sleep, Deep Sleep, Hibernate, and Stop. Table 1 lists the PSoC 4 resources and the availability in different power modes.
Table 1. PSoC 4 Power Modes – Resources Availability
Subsystem
Active
Sleep
Deep Sleep
Hibernate
Stop
CPU
ON
Retention
Retention
OFF
OFF
SRAM
ON
ON
Retention
Retention
OFF
High-speed peripherals (SPI, UART, and so on)
ON
ON
Retention
OFF
OFF
Universal Digital Blocks (UDBs)
ON
ON
Retention
OFF
OFF
VDAC
ON
ON
Retention
OFF
OFF
SPI slave and I2C slave (SCB based)
ON
ON
ON
OFF
OFF
High- speed clock (IMO, ECO, and PLLs)
ON
ON
OFF
OFF
OFF
Low-speed clock (32 kHz) (ILO and WCO)
ON
ON
ON
OFF
OFF
Brown-out detection
ON
ON
ON
ON
OFF
CTBs/CTBms (opamp and comparators)
ON
ON
ON
OFF
OFF
ADC
ON
ON
OFF
OFF
OFF
Low-power comparators
ON
ON
ON
ON
OFF
GPIO (output state)
ON
ON
ON
ON
Frozen
PSoC 6 Family:
PSoC 6 MCU features seven power modes of operation.  The system powers are Low-Power (LP), Ultra-Low-Power (ULP), Deep Sleep, and Hibernate. The Arm® CPU power modes are Active, Sleep, and Deep Sleep, and are available in the system LP and ULP power modes.
Table 2 lists the PSoC 6 MCU resource availability in different power modes.
Table 2. Resources Available in Different Power Modes
Component
System Power Modes
LP
ULP
Deep Sleep
Hibernate
XRES
Power Off with Backup
CPU active
CPU Sleep/Deep Sleep
CPU Active
Core function
CPU
ON
Sleep
ON
Sleep
Retention
OFF
OFF
OFF
SRAM
ON
ON
ON
ON
Retention
OFF
OFF
OFF
Flash
Read/Write
Read/Write
Read only
Read only
OFF
OFF
OFF
OFF
High-Speed Clock (IMO, ECO, PLL, FLL)
ON
ON
ON
ON
OFF
OFF
OFF
OFF
LVD
ON
ON
ON
ON
OFF
OFF
OFF
OFF
ILO
ON
ON
ON
ON
ON
ON
OFF
OFF
Peripherals
SMIF
ON
ON
ON
ON
Retention
OFF
OFF
OFF
UDB
ON
ON
ON
ON
OFF
OFF
OFF
OFF
SAR ADC
ON
ON
ON
ON
OFF(1)
OFF
OFF
OFF
CTBm
ON
ON
ON
ON
ON (lower GBW)
OFF
OFF
OFF
CTDAC
ON
ON
ON
ON
Retention
OFF
OFF
OFF
Analog Reference
ON
ON
ON
ON
ON
OFF
OFF
OFF
LPCMP
ON
ON
ON
ON
ON
ON
OFF
OFF
TCPWM
ON
ON
ON
ON
OFF
OFF
OFF
OFF
CSD
ON
ON
ON
ON
Retention
OFF
OFF
OFF
BLE
ON
ON
ON
ON
Retention
OFF
OFF
OFF
LCD
ON
ON
ON
ON
ON
OFF
OFF
OFF
SCB
ON
ON
ON
ON
Retention (I2C/SPI wakeup available)
OFF
OFF
OFF
GPIO
ON
ON
ON
ON
ON
Freeze
OFF
OFF
Watchdog timer
ON
ON
ON
ON
ON
ON
OFF
OFF
Multi-Counter WDT
ON
ON
ON
ON
ON
OFF
OFF
OFF
Reset
XRES
ON
ON
ON
ON
ON
ON
ON
OFF
POR
ON
ON
ON
ON
ON
ON
OFF
OFF
BOD
ON
ON
ON
ON
ON
OFF
OFF
OFF
Watchdog reset
ON
ON
ON
ON
ON
ON
OFF
OFF
Backup domain
WCO,RTC,alarms
ON
ON
ON
ON
ON
ON
ON
ON
(1) SAR ADCs in PSoC 62S4 can operate in Deep Sleep
References:
Version history
Revision #:
3 of 3
Last update:
‎May 05, 2021 10:29 AM
Updated by:
