Resources Available for CapSense® Controllers
Where can you find a comprehensive list of resources that you can use to design applications using CapSense® Controllers?
- This article provides a comprehensive list of resources that you can use to design applications using CapSense Controllers.
CapSense Controllers are categorized as follows:
Introduction:
Software and drivers: The following software is required for designing CapSense applications:
The following sections list the resources available for individual CapSense controller families:​
CY8C4xxx:  Product Overview
Development Kit
Code Examples
Design Resources
Application Note
Guides:
Component Datasheets
Technical Reference Manual
Datasheet
Knowledge Base Articles:
CY8C21x34/B:
Code Examples
Design Resources:
Reference Designs:
Component Datasheets:
Technical Articles:
CY8C20x34: Development Kit
Code Examples:
Design Resources:
Technical Articles:  Capacitive Sensing 101 Mobile Handset Touches on Capacitive Sensing
CY8C21x45/CY8C22x45:
Knowledge Base Articles:  Knowledge Base – Cypress Semiconductor Cage Code – KBA89258
CY8C24x94 :
Code Example:
Design Resources:
Component Datasheet :
Technical Articles :
CY8C20xx6A/CY8C20xx6H/CY8C20XX6AS :
Code Examples:
Design Resources:
Datasheets:
CY8C20xx7:
Design Resources:
CY8C201xx: Development Kit
Design Resources:
CY8CMBR2044:
Video:
Design Resources:
Knowledge Base Article:   Cypress Semiconductor Cage Code – KBA89258
CY8CMBR2016:
Design Resources:
CY8CMBR2010/CY8CMBR2110: CY3280-MBR2 CapSense® Express™ with SmartSense™ Auto-Tuning Evaluation Kit
Design Resources:
CY8CMBR3xxx family:
Videos:
Design Resources:
Resources on Proximity Sensing using CapSense:
Application Note:  Proximity Sensing with CapSense®
Video:
Technical Articles:
Resources on Water Proof CapSense Design:
Video:  CapSense Water Tolerance
Technical Article:  Waterproof Capacitance Sensing (Traditional Chinese)
For more articles on CapSense visit: CapSense Technical Articles
Technical Support: If you have any queries or questions, the technical support team would be happy to assist you. You can create a support request, or if you are in the United States, you can talk to our technical support team by calling our toll-free number +1-800- 541-4736 and then selecting option 2 at the IVR prompt.
You can also use the following support resources if you need quick assistance:
Version: *C
Translation - Japanese: CapSense®コントローラーに利用可能なリソース - KBA92181 - Community Translated (JA)
