Renaming the TopDesign.cysch File of a PSoC® Creator™ Project - KBA89006
Version: **
Question:
If there are multiple PSoC Creator projects in your workspace and the schematics of all the projects are named TopDesign.cysch, can you provide alternate names for the schematics in each of these projects?
Answer:
Yes, it is possible to rename the TopDesign.cysch file in any PSoC Creator project.
  1. Go to Source tab in Workspace Explorer. Select TopDesign.cysch and press F2.
  2. Go to Components tab in Workspace Explorer. Right-click on TopDesign and select Rename.
Contributors
