Remember to install QEMU before running ML (Machine Learning) Configurator at ModusToolbox
Harris_Chan
5 comments on KBA 10 questions asked 100 sign-ins
ModusToolbox (currently v3.1) contains several code example projects for Machine Learning applications.  After creating, building, and programming an ML project (such as Machine_Learning_Neural_Network_Profiler) to your EVK (such as CY8CKIT-062S2-43012 with CY8CKIT-028-TFT Shield), you may launch ML Configurator for machine learning model validation.  At ML Configurator, user can click:
Generate Source at General Settings tab,
Validate at Validate in Desktop tab or
Validate at Validate on Target tab.
In case there are errors, please check whether you have installed QEMU (a generic and open source machine emulator and virtualizer) from:
https://www.qemu.org/download
- Please download QEMU 6.2.0 as ML Configurator expects QEMU versions between 6.0.0 and 6.2.0 inclusively.
2021-12-15: New QEMU installers (6.2.0).
https://qemu.weilnetz.de/w64/2021/qemu-w64-setup-20211215.exe
Please also ensure adding below PATHs at your Environment Variables… of your computer.
IFX_MTBML_QEMU_PATH
C:\Program Files\qemu (or your directory where QEMU was installed)
Path
Then close ML Configurator and Eclipse IDE for ModusToolbox, and relaunch.  The ML Configurator errors should be gone.
INFO] QEMU application: Will use IFX_MTBML_QEMU_PATH environment variable
[INFO] QEMU application location C:\Program Files\qemu\qemu-system-arm.exe
[INFO] QEMU application version: 6.2.0
[INFO] QEMU: Executing C:\Users\chanharris\ModusToolbox\packs\ModusToolbox-Machine-Learning-Pack\tools\ml-coretools\ml-coretools-tflm-qemu-images\tflm-qemu-model-mem-calc-cm4
Contributors
